Hi. I've been trying to export from premiere cs5 to a format that will play smoothly, but having a lot of problems.
The project is premiere 2.0 and is mostly 480i footage shot with a dvx100b and some photos.
I exported the project out as uncompressed .avi 480i (lower field first) then opened a new 720p project in premiere cs5 in which I applied magic bullet frames to deinterlace it and magic bullet instant hd to upres it to 720p.
It plays a looks good from the timeline.
So I've tried all sorts of ways to export it to a file,
F4v, .mov, h264, mp4, flv... Vbr and cbr, maximum depth, etc.
And the only one that worked good enough to use was f4v, but it still had some jerky areas.
So then I just simply clicked "match sequence settings" and it changed it to .mpeg, quality 50 and virtually all the settings were grayed out. I went ahead and tried it and it worked great!
But once I copied the mpeg file to another computer it didn't play audio. ?! What is going on?
I thought I'd finally found the best solution.
To recap, the mpeg file plays great and with audio but only on the computer it was created on. I copy it to a flash drive and it plays great from there, too. But once it's on another computer it has no audio.
Any help would greatly be appreciated.
