David W. Richardson
Chapelgrove Films
I'm using Vegas Movie Studio HD version 11 (build 75) and am encountering a strange problem when doing a simple cross-fade from one clip to another.
During the transition itself, the pixel aspect ratio seems to change -- the image squeezes in from the sides a bit. Once the transition is complete, the image aspect ratio returns to normal.
I have a mix of clips on the timeline -- some shot with my Canon T3i, others shot with a Nikon DSLR. All clips are 1920x1080, all are progressive, all are PAR 1.000, and all are AVC (.MOV) files.
This issue occurs whether the two clips being transitioned are from the same camera or from different cameras. However, there are SOME transitions where this does not seem to occur, and I can't see anything different about those clips.
These transitions were created by putting the clips all on the same track and overlapping them. But I've tried putting them on different tracks and using the fade handles, and still get the same result.
This occurs when I do a selective pre-render. I am pre-rendering using the "NTSC DV Widescreen" template (.AVI), but I've made sure the settings in that template match the clips. I've also made sure the timeline properties match the clips.
So I'm kind of at a loss here.
What's interesting is that I used these exact same clips -- also in Vegas Movie Studio HD 11 -- in a different project and used similar transitions, and had no problems at all.
Any thoughts?
Any thoughts?
