egproductions
So i noticed that when you export a 16:9 clip using the quicktime dv/dvcpro NTSC codec out of premiere and import it back into your project the MOV clip by default uses 1.212 as apposed ot the 1.2 aspect ratio that normal DV AVIs use. If you have two identical clips but one is a MOV and the other a AVI you can actually seee that the MOV has wider pixels becasue the image is more pulled. Which one is right? Even if its not a noticble diffrence without comparing two sources this is very upsetting to think all my videos i have done could be .012 off.
