vocare said:Have anyone try to mount a dvx to a mountain bike.
Looking forward to any cheap and good suggestion
GageFX said:And judging by your post, you are absolutely brilliant.
Way to go.
-VOCARE...
Hope this can be of some help.
I would try something like this:
http://www.matthewsgrip.com/mse.php?show=product&cat=291&products_ID=23997
Clamp that onto the bicycle frame and then find some sort of attachment to put in the clamp that has tripod thread on it. I would search for it, but I'll let you do that work. Maybe just some 3/8 all thread rod clamped in the other end. I'm sure there is something commercially available made by someone.
And Fox, I hope you post in a Singaporean forum and get ridiculed for not speaking their language well. I cant even imagine how badly I would butcher Malay, Cantonese, Mandarin, or whatever language is native for Vocare. I'm sure in your brilliance, you would do fine.
So before you call other people stupid, how about pulling your own head out of your ass.
-GageFX
Daniel Wee said:Gosh, I don't know if I would want to do that with a DVX. If you've mountain biked before in Bukit Timah, for example, you'll know that it's a very rough ride and I don't think the DVX will survive the shocks, especially if hardmounted. Plus, it's actually quite a dangerous ride, even without all the equipment attached. I've got scars to show for it.
If you don't need the 25p footage, I'd just get a solid-state camera (SDR-S100?) and strap that to the side of the bike. That's more likely to survive. The quality isn't really up to the DVX standard but for these shots usually quality isn't a huge issue since you'll be jerking all over the place anyway.
Daniel Wee
Daniel Wee said:See my other response in the Hardware forum. Basically, having mountain biked in the Bukit Timah area, I seriously doubt that even that nice looking clamp will do the job properly due to the lack of shock absoprtion. It will be okay for regular cycling, but if you're thinking about downhill stuff, I'd be looking at a different solution altogether. It's bad for the DVX and it's dangerous for the cyclist. Except for the mildest biking (through the trail) it probably won't be worth the risk. As I also suggested, try using a solid state camcorder like the SDR-S100 and you can strap that safely to the bike and it won't get in the way. Picture quality won't be as good and it won't be progressive but it should work.
Daniel Wee
