I came up with a cheap and not too bad solution for using my UCR210D. I bought a generic still camera bag that perfectly fit the UCR210D and then cut a small hole for the XLR cable out of the bottom. Then I just hang the black bag off the tripod or off my shoulder for hand-held.
Hey, sounds like a good idea, but i'll be climbing a mountain and need something more stable. I'm afraid this might be swinging around too much. I thought I saw a post here awhile back about some type of holder for mics. Can't find the darn thing. Any ideas on sometype of case/mount?
What kind of camera are you mounting to? For beta cams or any broadcast size camera (ie Sony 900 or Panasonic Vari cam) I use BEC boxes attached to a Anton Bauer plate. If they have the V mount batts there is an attachment to bolt on the camera. For small DV cameras BEC makes a bracket. I also have a belt pack made by KATA if they don't want it on the camera. Check out BEC and all there wireless solutions (sounds like an ad doesn't it) http://thebecgroup.com
I'm happy with their products.
Good luck
A.G.
I've always fabricated my own mounts for all my equipment. With a basic sheet metal brake and a drill press you can make just about anything then finish it however you like.
