Hahaha I already tried screwing a screw in the winder and using a screwdriver. It seemed to work!!!!!
What I would like to do though is being able to change the lens for something sharper.
There is no flange distance as there is no flange - you need a lens mount for that.Any idea the flange focal (equivalent) for that thing is? I wonder if it'd be possible to remove the lens and add a canon lens mount...
Obviously, I was wondering how far the front of the camera is so that if you removed the lens you could attach a canon lens mount to the front. If the distance to the film plane is less than 42mm (44 for canon ff + 2mm for the base plastic for a lens cap) you could hack something quite easily.
