Motion Path and 3d stroke
kilmyneo
i have a circular path whit the stroke, then applied a 3dstroke and bend it , but also i want to create a motion path using particular to do a follow sparkle on the start which follow entirely to the end...there is a way to apply the circular and bended paths (stroke) to the motion path so that way it keep in the same position??? thanks.
I can't understand exactly what you're saying here, but I think this one piece of advice should settle it: almost anything you can do with 3d stroke you can do just as well with particular. Then you could have a secondary emitter or just two layers of particular, and your sparkle is guaranteed to position the same as your streak.
sorry about mi english hehehe, i just want to attach the sparkle with the 3dstroke, from the beginning to the end of this... the problem because i dont use 2 particular and motion path is because its really difficult to do complex movement whit the ligth.
