"motion blur", like Gladiator
Alexa
What is "motion blur" supposed to convey?
I am beta testing this effect for someone. Occassionally, I see the diffference, but overall, I wonder if/what I am seeing at all?
I got the impression that this effect was supposed to be similiar in nature to a fight scene in Gladiator. Where do you think this effect is appropriate for?
Re: "motion blur", like Gladiator
beta testing motion blur? Can you explain a bit more clearly?
Gladiator used a reduced shutter angle (faster shutter speed) On the DVX set the shutter speed as high as it will go if you want this effect.
Motion blur within FCP relates to when a clip is moved around you want it to blur naturally. This takes more render power but looks better.
[quote author=Kai link=board=FCP;num=1103512285;start=0#1 date=12/20/04 at 13:03:32]beta testing motion blur? Can you explain a bit more clearly?[/quote]
Sorry about that. I probably didn't write that correctly. Basically G. Nattress is adding motion blur to Film Effects 2.0. I asked if I could try out what he has "in progress." Some clips, I could see a bit of difference, but some I'm not sure what I saw.
[quote author=Scottdvx100 link=board=FCP;num=1103512285;start=0#2 date=12/20/04 at 15:23:29]Gladiator used a reduced shutter angle (faster shutter speed)   On the DVX set the shutter speed as high as it will go if you want this effect.
[/quote]
hmm, thanks for your response. It seemed to me, "blur" wasn't quite the word to describe the effect I saw..
anyhow, if you own FE already, I think he is welcome to have others try it out.
