Looking to find the most powerful bi-color 1X2 LED to mimic what I got from the Diva 401, which was a bi-color, relatively powerful light that I could diffuse the hell out of and still have enough pop for most interior interview situations. I like my key light as soft as possible so I really need a good amount of pop out of my next key light. Considering the Diva 401 was just powerful enough for this application, and was rated at 3000 lux at 1 meter, that's pretty much my low end output threshold since that's already a somewhat soft light coming in at 3000 LUX. I should mention that I fly to nearly all my jobs so I need something relatively portable. Also not looking for any crazy DIY setups, needs things to work, and work quickly in high pressure situations.
The Westcott Flex 1x2 has very powerful specs, 3500-3900 LUX at 1 meter, whereas the Kino Select LED, at the same 100w power and size, is rated at only 2740 LUX, but thats after running through the built in diffusion panel, whereas the Flex is a bare hard light at that LUX rating. Without the ability to test these out side by side, how best should I compare the output between natively diffused and undiffused light sources?
Which other lights should I consider in addition to the Westcott Flex and Kino LED lines? Cost is certainly a factor but if I can check off all my boxes with one light, i'm willing to bite the bullet.
Checklist:
Bi-color
Portable (under 15lbs so I can put on standard light stand, max 1x2 in size to fit most suitcases)
3000 LUX @ 1 meter bare minimum output
Reliable and fast set up
Battery power is a bonus not a must
Softbox pairing is important
Checklist:
Bi-color
