morwe than 70 dnxhd files in vegas make it crash
macgregor
The moment I tried putting on the timeline +70 DNxHD files, the program just freezes. It doesn´t matter how long the clips are, or how do I import them. It doesn´t want to take them.
Im running Vegas 12 in W7. Any ideas?
Edit: OK I just tried on Vegas 10 and same thing happens. And I tried in 2 different computers.
It's driving me nuts because this didn't use to happen and now it's happening in 2 compeltely different machines. This is the error I'm getting:
Problem Description
Application Name: Vegas Pro
Application Version: Version 12.0 (Build 563) 64-bit
Problem: Unmanaged Exception (0xc0000005)
Fault Module:
Fault Address: 0x000000002BFF2021
Fault Offset: 0x000000002BFF2021
Fault Process Details
Process Path: C:\Program Files\Sony\Vegas Pro 12.0\x86\FileIOSurrogate.exe
Process Version: Version 12.0 (Build 563)
Process Description: File I/O surrogate (not visible)
Process Image Date: 2013-04-03 (Wed Apr 03) 21:13:00
This is a stab in the dark but see if this tip from the Sony Vegas forum helps.
Locate the following folder (you may need to enable Show hidden files and folders in Windows' Folder and search options):
C:\Users\[user name]\AppData\Local\Sony\Vegas Pro\12.0\Media Pool Thumbnails
Delete the contents of that folder. Then return to Vegas and switch your Thumbnails view to List or Details.
Mike
