I have a Mac G5 2.7 GHz with a Dell Ultrasharp 2405FPW 24" LCD monitor. I set the resolution to 1920 x 1200 which is the highest available.
When I purchased this monitor to edit video in FCP, I knew it wouldn't perfectly match the color of a normal TV, but I still thought I could do some decent video editing. However, I seem to have a problem with resolution.
Simply put, video on my 24" LCD has pixelization. The same video on my 65" rear projection TV which clearly has less resolution has no pixelization.
Just to clarify the pixelization problem...imagine you are looking at a picture of trees. On the 65" television, you seem smooth action of the leaves blowing in the wind. On the 24" LCD monitor, when the leaves move, it kind of looks like they are moving behind a stained glass window or a frosted shower door. Although the still picture is stunning, small movements in complicated color patterns create this effect.
I'm having a problem understanding why more resolution seems to equal more pixelization.
Do I have a setting wrong or is there some logic that I don't understand?
Thanks in advance for any light you guys can shine on the subject.
Thanks,
Kelly
Thanks,
Kelly
