MM-1 for DR100 MKII?
Bacon!
I have a TASCAM DR100 MKII and I'm looking for a preamp to reduce the noise level. I have a RODE NTG-2 and the external recorder doesn't have quite enough gain to get clear audio. Would the MM-1 be a good choice for this? If I'm not mistaken, the line-in would allow me to bypass the DR100 MKII's preamp entirely (correct me if I'm wrong, I don't know a lot about audio equipment). I am on a budget, so I'd prefer a price-concious solution.
The Tascam DR-100 MK2 is a great recorder if you can stay away from using the HIGH mic gain setting.
If you have to use the HIGH gain setting, then adding a good mic pre-amp ( like the Sound Devices MM-1 ) should take care of things.
Here are my RMS noise-floor test results for the DR-100 MK2.
I consider a RMS noise-floor below -60 dB to be noise free, but keep in mind that any volume boost in post will also raise the noise floor.
So if you raise the volume of a recording by 10 dB, then the new RMS noise-floor is 10 dB higher than it originally was, so a -60 dB RMS noise-floor becomes -50 dB after the volume change, and you may start to hear noise in the quiet parts of your recording. This is why you want to use a recorder that has a better than -60 dB RMS noise-floor.
Tascam DR-100 MK2
MIC GAIN SETTINGS
RMS MIC NOISE FLOOR : MIC GAIN = LOW
MIC LEVEL 2 : -83 dB
MIC LEVEL 4 : -84 dB
MIC LEVEL 6 : -84 dB
MIC LEVEL 8 : -83 dB
MIC LEVEL 10 : -84 dB
RMS MIC NOISE FLOOR : MIC GAIN = MED
MIC LEVEL 4 : -83 dB
MIC LEVEL 6 : -83 dB
MIC LEVEL 8 : -80 dB
MIC LEVEL 10 : -79 dB
RMS MIC NOISE FLOOR : MIC GAIN = HIGH
MIC LEVEL 2 : -79 dB
MIC LEVEL 4 : -72 dB
MIC LEVEL 6 : -63 dB
MIC LEVEL 8 : -55 dB
MIC LEVEL 10 : -53 dB
RMS LINE NOISE FLOOR
LINE LEVEL 2 : -84 dB
LINE LEVEL 4 : -84 dB
LINE LEVEL 6 : -84 dB
LINE LEVEL 8 : -80 dB
LINE LEVEL 10 : -79 dB
Thank you for the quick and comprehensive post! I do have to use the HIGH setting to acquire useable audio, so it looks like an external preamp is the path I'll be taking. Is there a better alternative, or does the MM-1 seem like a solid choice for this issue?
The MM-1 unit is designed to be used by a boom-op, and has a good headphone amp built-in, so your boom-op can get a very clear idea of what the mic they are booming is picking-up. This unit does not have to be used by a boom-op, but it's handy that it can be used this way.
...As far as other high quality mic pre-amps go, I would consider a few other options:
1- JuicedLink Riggy unit ( like the RA222 or RA333 ) which outputs MIC level audio with 30 dB of clean gain. ( the MM-1 offers up to 66 dB of clean gain ) The price is in the MM-1 ballpark.
2- Sound Devices MixPre Mixer ( old model ) Used : A little hard to find, but you should be able to buy one under $500. This unit does everything the MM-1 does, but with 2 audio channels, has an LED audio level display, a 2-stage limiter, a 1 kHz test-tone generator which enables you to properly calibrate your camera or recorder audio input levels, a tape-out to feed a digital recorder while the main XLR LINE outs connect to the camera if you like ( I started with a MM-1, then one year later I bought a MixPre which I used for 4 years, and this year I upgraded to the newer MixPre-D mixer. )
3- Sound Devices MixPre-D Mixer : $750 new and updates a lot of things from the old MixPre mixer. Much nicer LED audio level display, inputs and outputs are switchable between MIC and LINE levels, can be used as a digital audio interface to your computer. It's a lot more money, but it will last for years and still keep it's resale value, so you could sell it a few years down the road and get most of your investment back. ( just make sure you always keep it in a case, so it stays clean and looks good )
All of these choices will have you covered in terms of producing good sound, as long as you ( or your boom-op ) does a good job placing your mic.
Regarding the 1khz test tone generator, what level do you normally set the recorder or camera to? Cheers.
I also have a DR100 and just decided last week to go with an MM-1 pre-amp to take away the gain on high, which is needed with my Oktava MK012 to get it to peak where I need to. I tested this off brand / no-name mic pre-amp and it took away the gain noise completely, so it gave me some confidence that going an MM-1 would likely solve the problem. Mine will be here within a few days.
Digital recorders have no recording headroom, thus we have to create our own headroom by setting a recording level below 0 dB.
With low cost equipment that tends to have a fairly high noise-floor, most people will use the 1 kHz test-tone to establish a recording level of -12 dB, which provides you with 12 db of headroom to capture louder sounds.
With higher grade recorders ( like the Sound Devices recorders ) you may have a noise-floor that exceeds -100 dB, so you can afford to allocate 20 dB of the recorders dyanmic range for headroom and still have 80 dB of usable recording range.
The short answer: Most people calibrate the test-tone to -12 dB. If you're using a Sound Devices recorder ( or something similar ) you can calibrate to -20 dB.
Nice, tell us how it works when you get it!
Also, are you using the original or the MKII?
