I'm wondering if anyone has tried using the MixPre-D's AES/EBU output to send a digital signal directly to a low-budget recorder, using the recorder as only a "bit bucket," and bypassing its preamps and A/D converter?
Let's say you make a custom cable that goes from female XLR to 3.5mm TRS (matching the TRS converter cable that comes with the Tascam DR-100 MKII; this digital input cable has the tip, plus three rings and three sleeves). And this custom-made cable also converts the signal from 110 ohms to 75 ohms, which I believe is what it needs to turn the AES signal into the S/PDIF signal that the Tascam is expecting to see.
So you're using the preamps and the A/D converter on the MixPre-D and sending a pure digital signal to be recorded by the Tascam. Theoretically, wouldn't that give you a great, low-noise recording, much better than you could get with the Tascam by itself?
Problem is, I have not found anybody who has A/B'd this combo in the real world with their own ears.
I did find a guy who has gone digital out with a cable like this from the MixPre-D to an Edirol R44, and much to my surprise, he said, "I bought the custom cable, so I had the ability to use the Edirol as a bit bucket. That is what I use it for, ocassionally. Mics go into the MixPre-D, which sends it digital to the Edirol. This way I only have to set the levels properly on the MixPre. The Edirol does not add anything to the sound."
"And to be honest, I have not really found any difference compared to recording straight into the Edirol. But it's just nice, I can record from the MixPre-D to a Sony M-10 (analog) and R44 (digital) at the same time (backup)."
Now maybe the Edirol R44 is a really good recorder (price, around $1,100), but I am a big fan of Sound Devices after recording with the 722 for a few years. It seems like if you could capture the pure digital out from the MixPre-D, and then compare it to a recording done with the same mic directly into the Tascam's preamp, using the Tascam's A/D converter, the MixPre-D recording would be much better. Anyway, that's my theory.
The question I'm asking myself is: Would it be $800 better, basically the cost of the MixPre-D plus the custom cable?
Recommendations and advice much appreciated,
jimbee
jimbee
