I am shooting a Pageant this weekend with 3 different cameras. Canon HG 21 at 1080i60, Panasonic AG-HMC150 at 1080i60 and a Canon 7d at 1080p30. All 3 will be used in the cut. Obviously I am going to have some interlaced and progressive footage. I was planning on using Apple Pro Res, 1920x1080 upper field first sequence in FCP 7. Any problem with mixing in the progressive clips from 7D into this? Also, the final output sadly will be DVD, so when I go to export to compressor, should I enable frame controls and set output fields to progressive, upper, lower, or same as source? If I choose progressive, or upper/lower, I then have to deinterlace, which I would set at best. Or do I just leave frame controls off?
Thanks for any advice.
