mixer vs field recorder
Is there a reason why all these portable field recorders only have XLR in's but no XLR outs? I've looked at the marantz pmd671, the fostex FR-2 and most recently looking at the new Tascam. I'm trying to kill 2 birds with one stone here. To be able to use a portable field recorder for mixing as well as recording sound effects. I appreciate any assistance you could give. Thanks
yes - money .
the rca are good enough to hook it analog with peripheral equip , usually you don't do it at all since the data flow is threw the cf or firewire/usb , the analog outs usually use for hooking amp or mixer return for spot check in the field.
to kill some birds you need much expensive rifle, which start about 8k with pd-6 and go up with hhb,Deva or cantar.
but with 3 channel mixer you can create very nice setup of 3 to2 recorder or 3+2inputs mixer while connecting your recorder to the main bus ( forget about shity dv mix or 442 crap rolls)
so 2 grand at least is what you are looking for
of coarse you can live the recorder at home if you don't need 5 inputs :-)
The 744t has both balanced analog and digital output. Downside is you only get 2 preamps.
Best
wrong answer - you cant mix with them , you dont have ext monitoring ( ok you can hook 3and 4 for that on 744 but its a joke )
The reason is that recorders are recorders, and mixers are mixers. The only real recorder that has capable outputs is the Deva IV or V, and those are pretty spendy.
-Dave
ExileOnTheMainStreet said:
wrong answer
Didn't know this was a test. :)
But you can mix channels on the 744t. I regularly put 3 inputs on channel one and then seperate them on the remain 3. If you are outputing to a camera, this works fine. Again the problem is you have 2 preamps so without another source for preamps you are left with just 2 workable inputs. Of course if you have the money for this price point, a Mixpre would not be a huge stretch anyways.
Either way a serparate mixer is a much easier solution.
Best
this is not a test but lets be presice
you cant fade the channels on 744 so the mix pre would not help you if you need eliminate one of the 744 preamps fast , you can make scratch track for editing or use the 744 as dual preamp.
not to mention that 744 is a real pain in the ass routing the inputs fast
The Nagra Ares-BB+ is great little flash recorder with 2 inputs, and 2 xlr outputs... Its not something I recommend running without, say, a Sound Devices 302 or 442 on the input side to give you some tactile faders/knobs and awesome preamps...
Just my 5 cents.
Just my 5 cents.
Oh, and, just from my experience, the only recorder that could really also be considered a mixer is the Aaton Cantar.... damn that thing is cool.
the Aries ( i didn't work with ) if i am not mistake don't have ph power so need external box anyway if you intend to run it stand alone
hey,
no, ive used them a lot (we have them at film school), and it does have phantom on both inputs, as well as low cuts, and quite a bit of other stuff. The only problem is it only has up/down buttons for level settings - not too user friendly...
I really like it though. Not heavy on batteries either...
