Hello,
I have a question regarding the sound I’m capturing from my mixer and recorder. I’m new to using these pieces of equipment and fear I may be overlooking something simple or just a standard setting.
I’m recording using an AT4073a shotgun mic going into a DV Promix 3 mixer. I’m then using a 3.5mm cable from the mic output on the mixer to the line in input on an Edirol R-09 recorder.
The sound is fantastic when listening through the mixer and the level readings are fine. However, the recorder does not have strong readings (usually in the 40 to 30 range) and it sounds much softer after it is played back on the recorder. When I transfer the data to a computer and listen to the files on Avid they sound very, very low, even when the volume is on full blast.
Am I routing this wrong? Is there a setting I’m missing on the mixer, recorder, Avid? I’ve fiddled around with stuff but can’t improve it. Thanks a lot in advance to anyone who can help me.
