I have a clip that keeps disappearing out of a FCP capture folder. I'll open the project and it asks if i want to reconnect. It has happened to the same clip twice now. I have to keep dragging it from my back up to replace. Can someone tell me why ?
1 Are you changing the file name?
2 Are you changing the file location?
3 Have you saved the project?
4 Did you "Re-Connect" media, or just "drag & drop" the clip back into your bin?
5 If yes, to #4, did you delete the "offline" media from the bin?
This, or something like this, happened to me recently. It did not repeat or happen again, but I had no backup. To make matters worse I had captured 15 tapes on 2 different computers and had accidentally labeled 2 clips the same. When I went to batch capture, you guess it, I used the wrong tape. I found no info on the web and finally called an old friend. He said it just happens sometimes with FCP. I have been using FCP since version 3 and it has never happened to me before or since, knock on wood. My answers to the above questions would be NO, NO, Yes, N/A, N/A.
I would love to hear if I missed something and if this has happened to others.
