After much reading on here, I've paired up this combo for our HVX. The spec and feature-set are great. It's light, stiff and well made.
The trouble is after 15 years of regular tripod useage I'm struggling using the miller legs in an intuitive way.
For instance, when you open up the legs to the first click (for height) which keeps the legs fairly tight there appears to be a degree of flex in the shoulders of the legs (not terrible).
But when you then move the legs to the medium stage, which makes it very stable - you then have a huge spread of legs that makes working in tight space awkward.
Does anybody have any general tips on what set-up they tend to go for, and any combinations they like?
I often find myself in the wrong setting and because you have to drag the legs all the way out to unclick them and sometimes find you don't have enough room.
Also with regard to the head, the HVX is on the 0 plate setting setting and I reckon it's still back heavy. Have people managed with the standard plate or do you need to change the plate?
Thanks.
Thanks.
