OnTheHorizonMedia
First of all, I'd like to tell all of you that I've learned a lot in the last couple of days about micorphones by going through a lot of the audio threads here. I value your opinions.
The questions I'm going to ask probably were already mentioned in these threads, but I'm confused on a few items:
1. For indoor use, it is suggested to use a hypercardoid micorphone instead of a shotgun mike...why? Can you use a hypercardoid mic (like the AKG w/CK93 capsule - I'm considering this mic) with a boom? How is the pick-ups for indoors? Could you use it outdoors also?
2. For a wireless mic set-up, I was thinking of the Sensheiser G2 100 series combo unit. For the plug-on transmitter, I was thinking of a Shure SM-58.
I plan on producing information/training videos and produce a few commercials for our cable company.
I already allocated $4k for the 100b/tripod/cases/extended warrenty/etc. I only have $1k available for the audio portion.
Would the mics I pickeds be an all-around good system to have? Any other suggestions? I want to make certain that these mics are a good starting point and can even be used as my audio equipment needs expand.
Thanks.
Thanks.
