ozmorphasis
I'm looking for a cable clamp that can be easily mounted on a 1/4-20 hole on my GH5 cage. I have the Panasonic XLR1 unit, but the strain relief is attached to the unit itself, which doesn't help with the main strain concern - the camera hot shoe. I don't care about the cable, but these hot shoes will not take a ton of abuse, so I want any yanking on the cable to terminate at the cage, not the xlr unit/hotshoe.
I might be able to use an HDMI clamp, but I prefer the plastic type like on the xlr unit itself, or like the ring cable guides that you see on studio and stage microphone stands. In other words, you just press the cable into the tight fitting plastic clamp, no screws or adjustments needed:
Here is what Panasonic attached underneath the XLR1 Unit. Plastic, but exactly what I want...but instead with a 1/4-20 mounting option on the cage.
Here is what you see on Microphone stands, or a similar variation. Again, totally does the trick, but I want it 1/4-20 mountable.
