Microfiber cloth...
TylerGred
I wasn't sure where to post this so I'm sorry if it's in the wrong area.
I just wiped my monitor off with a microfiber cloth and now it's dusty. My question is can I wash them? I have no idea what so every if you can. If not, how should I go about cleaning it? I bought it for my DVX lens, but I do not want to wipe it until it's clean. Thanks.
Re: Microfiber cloth...
Your computer monitor? I use a cloth that is specifically made for Flatscreen LCD cleaning; its a kind of 'wetnap' with a cleaning solution (mild soap Im sure). It works great on my monitor as well as my DVX100 LCD.
Now, for DVX LENS and UV and Glass Filters I use only a microfiber cloth with NO CLEANING SOLUTION. Just condensation from 'puffing' on the glass and then lightly cleaning.
I would'nt use the same one on your computer and THEN on the DVX by the way.
Yeah I didn't John. I have one I only use for the DVX. The one I got dirty I got in a Sam's Club lens cleaner pack with another one. However it's the same type cloth I use for the DVX. I won't switch the clothes around. Now that we got that out of the way, can I wash them or are they no good after they get dirty.
Tyler--No problem, when your microfiber cloth gets dirty, rinse it out. You can also use a small bit of mild detergent if it needs it.
[quote author=Barry_S link=board=Links;num=1088970135;start=0#3 date=07/04/04 at 20:52:59]Tyler--No problem, when your microfiber cloth gets dirty, rinse it out.  You can also use a small bit of mild detergent if it needs it.[/quote]
Simple green does the trick for me. Just a drop, or you will be sudsing it out all week.
SIMPLEGREEN is bringing up bad memories of the Coast Guard. I think the Government has stock in this stuff :P
[quote author=John Hudson link=board=Links;num=1088970135;start=0#5 date=07/04/04 at 23:52:42]SIMPLEGREEN is bringing up bad memories of the Coast Guard.  I think the Government has stock in this stuff  :P[/quote]
What do you think they use for your shower gel, shaving cream, tooth paste, and to make the ice cream taste creamier?
[quote author=John Hudson link=board=Links;num=1088970135;start=0#7 date=07/05/04 at 00:23:31]I thought it was kelp?[/quote]
Not in the Coastguard. Simple green and cow hooves. Only the best for the boys and girls in blue (or whatever the feck color you are wearing now).
I was told to clean my lens with cleaning solution and microfiber cloth. I bought some lens cleaner from the optical department at Sam's Club. I spray it on and wipe it with the microfiber cloth.
[quote author=TylerGred link=board=Links;num=1088970135;start=0#10 date=07/05/04 at 08:38:56]I was told to clean my lens with cleaning solution and microfiber cloth. I bought some lens cleaner from the optical department at Sam's Club. I spray it on and wipe it with the microfiber cloth.[/quote]
Lenses have a thin layer of coating which does a series of things from reject some UV to prevent baffle flare. A purist would say baby that layer as without it, you don't have a camera. The question is, how long will the camera have to produce optimal pictures for you before it is replaced.
With water on the lens leaving spots, I know of no other way to safely clean it than liquid and microfiber cloth.
I just picked up this cleaning cloth from the computer store to use on my flip out screen and it worked! Smudges are gone! I did also buy some Screen Cleaning wipes but the cloth did the trick.
