My first post ever! Thank you to all on this board and especially those who created it!
A laundry list for Michael P., or any others out there:
First off, Michael, your mini-tutorial on Sorenson settings helped me get two projects done for the holidays. Do you have an official website? If you're ever in San Jose, I owe you beers.
That being said, let's start with Sorenson. The two projects completed were shot at 24pn, and when completed, I highlighted the proper sequences, selected 'send to', then the sub-menu 'encoding', then Sorenson. The .mov file was created, then I squeezed and made the mpv files. No problem.
My main question is: when you start a fresh project and choose 23.976 as the frame rate, digitize your footage (I'm using an older Panny pv-dv203 palmcorder--no problems) edit and so forth, why is it that you can't send to Sorenson through the encoding menu? It simply doesn't pop up like the 24pn/30i frame rate selected projects. I tried to go around it and selected 'send to DVD' through the quicktime reference, then dragged that into Sorenson, but then the burned DVD looked absolutely blurry (think of the 'agents' dodging bullets in The Matrix) This led me to believe that somehow the extra 'judder' frame wasn't being deleted, but that step would have to be done while digitizing into Avid Xpress Pro, correct?
(version 4.5 by the way)
And while I'm seeking answers:
How do we use/interpret the timeline in the 23.976 projects? Under the audio layers are tracks labeled 24, 25, 30...etc. I can highlight them but can't seem to see how any affect my editing.
Also: when digitizing in 23.976 I can see the footage fine in the client monitor (actually about a second ahead than what is playing) but when playing back from the timeline, it doesn't loop through the camcorder. No, I don't have mojo yet, but still, the 24pn projects play back through, although there is a delay. And speaking of monitors, why is it that the 23.976 project setting, 'video display' is different than the 30i projects, where you can tweak the settings of a client monitor?
Congratulations if you've made it this far. I know this is a lot, but what better place to ask?
Cheers,
Brad
Cheers,
Brad
