Noiz2
Sound Ninja
I'm guessing this has to be battery powered. THe reason is that being battery powered is going to raise the price a bunch. But the cheapest way generally to get four mic pres is to use a mixer that has direct outs. You can use a mixer that only has a stereo out because you are not going to be using the "mixer" functions. The mics go in the trims are usually the only thing that comes before the direct out, so you take the direct out which is now at line level. You would only need a four (mic) channel mixer so generally pretty cheap. Except that few that are set up to run off batteries out of the box are cheap. The old Mackie 1202's can be wired to use an external battery and they will give you four clean mic pres with direct outs.
