morten
I've read a pile of these mini 35 threads with a mix of great interest and awe at the number of different products, diys and experiments are out there. One thing I have yet to find tho is an experiment using medium format lenses rather than the tried and tested 35s.
I have an old Hasselblad 500cm lying around that I'm not using. Now reading all of these threads it strikes me that a medium format camera might actually be a much better sollution to the endless quest of the perfect film look than a 35mm lens setup. The reasons? The lens is bigger for one. and the lens quality is superior to any other lenses out there. Also, the old Hasselblad lenses are fitted with "teeth" allready on the focussing ring which should make it a lot easier to build a follow focus to fit. Most medium format bodies also come ready with a detachable backpiece which makes it almost comically easy to figure out where to put the gg - simply take the backpiece off and put a gg on instead. done.
I realize that there are some other issues involved as well... like the prize of medium format lenses. But then again, older style Hasselblad lenses and smashed bodies are going for fairly decent prices on ebay and you can find them at swapmeets. Truth is the old style fully mechanic medium format camera is dying out at an alarmingly fast rate so there should be plenty of the bodies and lenses available to grab in the future.
Now for the setup. Like I said I have a Hasselblad 500c/m lying around. I have no intention of rendering it useless as a photo camera so picking it apart is out of the question. I should however be able to find a non-working body for it for not too much money which will give me if nothing else at least a lens mout. Then I can use a pvc pipe cut to the exact lenght of the camera body and put a gg at the other end. this rig will produce a crystal clear 6x6 cm image on the gg with plenty of dof (the lens is 2.8 fully open).
Ofcourse this is all nothing but speculation at the moment. I just want to hear what people think about it.
On a different note:
I notice how "everyone" seems to want a DVX with a 35mm lens mount rather than the lens that comes with it. So why not make one. I'm sure there are a few DVX bodies with busted lenses kicking around out there. Let's say you got a hold of one, ripped the whole lens assembly out and retrofitted it with a 35mm lens mount instead. bypass the whole gg issue and focus the lens straight at the CCDs.
Or do one better. Why not create a DVX style camera that uses 35mm lenses right out of the box? maybe that's a new avenue for Panasonic and the other manufacturers?
Or maybe I'm an idiot. You tell me.
mor10
mor10
