Hi guys,
I'm planning on buying matteblox with French flag, however one thing I'm still not sure about is: Will I be able to use color filters with it?? I read at few places that the filters set that you can buy with matteblox is not very good so I was thinking if it would be possible to use one of these setups menationed before??
Thanks a lot, reading through your comments and ideas how to tweak out our toys is hurting my wallet...ouch :-/ ;D ;D
Dan--you don't want a ND Grad that mounts directly to the lens--you can't move the transition up or down or tilt it. A fairly inexpensive solution is to buy a Cokin P filter holder ($8 ), a 72mm adapter ring ($9 ), and a P-size resin ND Grad filter. I like HiTech (aka Formatt) ND Grads ($40 )--they're reasonably priced and excellent optical quality. You can also buy a cheaper Cokin brand ND Grad ($18 )--it's probably fine for video use. The main drawback to the cokin ND Grads is that the density is not completely neutral--it may have a slight tint.
You can mount the 72mm adapter ring to the front of the polarizer on your camera. ND Grads usually come as hard-edged or soft-edged. The soft is easier to work with, but the edge definition varies a lot depending on the manufacturer. You can also buy inexpensive lens hood attachments for the Cokin P holder, or rig something of your own.
http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=deta ils&Q=&sku=14265&is=REG
http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=deta ils&Q=&sku=14095&is=REG
http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=deta ils&Q=&sku=111013&is=REG
http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=deta ils&Q=&sku=238968&is=REG
