matrox question
teupaksa
matrox mxo sounds fantastic. but i just gotta ask some question to make sure i have understood it right:
- is it so that i can view my clip on apple cinema display like it was on a television set. hence no interlacing artifacts?
- using apple cinema display 30" with matrox and macbook pro. how would i use it for both editing and previewing at the same time? do i have to edit first and then turn on the matrox to preview in broadcast quality? But then i wont be able to directly compare what is going on on the preview and the computer... or could i use the lcd on the macbook- pro for that?
- what is the main reasons for purchasing a matrox. is it mainly used to get the colors right on your output? see how everyting will look like on a final result?
hope someone can clarify this and how your workflow is with this kind of setup. i read Shane Ross´s article which is very good and informative, but didnt quite answer my questions.
here is a link to the article by the way, in case you havent read it:
http://library.creativecow.net/articles/ross_shane/MXO.php
teupaksa
