Spec-Comm
DVXuser Sponsor
Hello everyone,
Just wanted to check in with you about the new Matrox MXO system made for FCP.
Below are the features:
• DVI to broadcast-quality video conversion in HD and SD
• Portable, hot-swappable external box
• Genlockable HD/SD SDI, HD/SD analog component, Y/C, and composite outputs
• Up to 8 channels SDI embedded audio output with stereo audio monitoring
• Workflow enhancements for Final Cut Pro and other QuickTime-based applications
- Conversion of DVI preview output to frame accurate broadcast-quality video for insert editing and print-to-tape with guaranteed audio/video sync
- Interlacing artifact elimination and gamma correction when previewing video on a secondary DVI display
- Hardware accelerated output of DVCPRO HD, HDV, and Final Cut Pro Dynamic RT segments
- Realtime downscaling of an HD project to SD resolution with proper color space conversions
• Flicker-free, broadcast-quality video output of your computer desktop with any application
They list for $995. We are offering a DVXuser discount! $969.00! Please contact us if you need more information on the MXO or if you would like to place an order. They should be here at our facility soon so act fast!
Best regards,
Andrew Hoffman
Senior Operations Manager
Specialized Communications Corp.
20940 Twin Springs Dr.
Smithsburg, MD 21783-1510 USA
800-359-1858
Fax: 301-790-0173
andrewh@spec-comm.com
www.spec-comm.com
Best regards,
Andrew Hoffman
800-359-1858
Fax: 301-790-0173
www.spec-comm.com
