matrixed stereo decoding in FCP
Are there any audio filters available to decode M-S (mid side track pair) from a Neuman RSM 191AS or Sanken CMS-10? The Waves Stereo Imaging Plug-in will do it in Logic, but I'd like to find a solution inside FCP or at least in Soundtracks.
Hi Bill:
I'm not sure what's built-in to FCP and soundtrack for this, and can't check right now... but basically, pan your Mid signal center, duplicate your side track (or bus it to two aux tracks if you can, even better) to get two identical tracks panned L and R. Find any plug-in or setting that will let you invert the R track. Keep L and R levels exactly the same, and adjust the ratio between Mid and (L&R) levels to modify the width of your stereo image.
Voila! You're dematrixed!
I'll check back to see if you've figured out how to do this in FCP and Soundtrack Pro.... let me know how it goes!
