Thomas_E_SP
OK. so, I had to some ADRs, it's for an exterior shot that got cut off by a truck passing (nyc, yes..). It cuts only the lines of one character, so I only asked this one actor to come and re-record those particular lines. ( those lines were half improv'd so I didn't have another take).
Then, because he had almost a monologue there, I only recorded the second half ( was afraid that recording from the top would make the end, what I need, out of sync...I chose to record almost only the lines that got cut off..stupid. )
It gets worse: I recorded with a different mic and into minidisc, instead of into the dvx with the omni mic that I used for the shoot.
As you can expect, it doesn't quite match.
Any suggestions? I've used ambient noise of course. maybe a filter that I should play with...Anything.
it sounds like it's coming from someone else in a different location. ( aahh! )
The interiors are better though, not perfect, but better.
