MASK in VEGAS4 and VEGAS5
MOJE
If I making mask in VEGAS4 as on PICTURE
and I select REGION and PRINT TO DV VEGAS4 is not render !!!
If I make mask in VEGAS5 (ar load the project from VEGAS4) as on PICTURE
and I select REGION and PRINT TO DV in VEGAS5, VEGAS5 is RENDER !!!
WHY ???? :-[
THANKS
PS: SORRY I am not good in English language ::)
Re: MASK in VEGAS4 and VEGAS5
What region are you trying to use in Vegas 5? The picture does not make it clear.
If I am understanding correctly; you have to stretch the MASK out, extending it as far as you wish to use it. CLICK and DRAG
If I SELECT REGION mmm IN VEGAS 4 and PRINT TO DV - it´s OK - WITHIN RENDERING
If I SELECT REGION mmm IN VEGAS 5 and PRINT TO DV - VEGAS is RENDERING :-/
WHY? :'(
If I SELECT REGION mmm IN VEGAS 4 and PRINT TO DV - Video is printing to my DV CAMERA without render (in region mmm I don´t use mask)
If I SELECT REGION mmm IN VEGAS 5 and PRINT TO DV - Video is print to my DV CAMERA with RENDER (in region mmm I also don´t use mask, but VEGAS5 is RENDER :-[)
PS: my project render in VEGAS 5 LONGER as in VEGAS 4 ??? VEGAS 4 render ONLY MASK, but VEGAS 5 RENDER ALL PROJECT :-[
Do you have "recompress frames" set in Vegas 5 and not in Vegas 4? That would probably do it.
May You help Me? How make this project in VEGAS5 without "recompress frames"?
THANKS
PS: May You take picture here?
MOJE -- I don't have Vegas in front of me to double-check; I can do it later. But check the Help file for "recompress."
