Making someone look pregnant
awelgraven
I'm shooting a short film in a month where the lead actress is pregnant during the entire film. I'm going for more of a baby bump than anything "too pregnant" :)
Any suggestions on how to do this? You would never see any skin, but I need it to be clearly visible and realistic looking under clothing.
Any help would be greatly appreciated!
-alex
Costume houses rent strap-on 'pregnancy pillows' to wear under clothing.
You can make one yourself for cheap with a properly-sized/shaped throw pillow or chunk of soft foam; stitch on a couple velcro straps to hold it in place and you're golden.
A cheap version that I've seen work pretty well is a kid's (depending on size) bicycle helmet. Put the helmet on the stomach and then wrap the person and the helmet in an Ace bandage. Provided you get the right helmet, I think it works pretty well.
For a couple of our films, we took a soccer ball and cut it in half. Actually, not quite in half -- one side a little bigger than the other. We took the slightly bigger side and stuffed rags into it to give it a little weight. (It probably wasn't enough.) Cut slits in each each side and ran cloth strips through to make a 'belt', which tied around the actress's waist. Dressed her in a maternity blouse, and that did it.
Full-leg nylons stuffed with filler work well. The 'legs' make it incredibly simple to attatch to your actress and the texture is much more skin-like than other alternatives.
