making slo mo uniform
tony404
I had to reach a certain amount of time so I started slowing the clips in the project just a touch.Its not noticable but it helps me reach the time without having the footage. Im eyeballing all the clips in the timeline is there a way to do it so they are all the same. Thanks
Yeah.
Right click the footage, select Properties, and in playback rate, you can set it just how you want. Then, copy the clip you've modified, select all other clips you want to modify, and right click the first of those new selections.
Then "Paste Attributes."
This will slow all other frames.
Caveat: Any color correction/filters, pan/crop, or other attribute found on the first clip/event will then carry over to the other events.
