Hello there!
I'm having major problems with CS4. I recently bought a new computer - essentials are as follows:
Intel Core i7 920 2.66GHz
2 x Kingston 3x2GB, DDR3 1333MHz (=12 GB RAM)
Ati Radeon HD 5770 v2
Asus P6T SE, LGA1366, X58, DDR3, ATX
2 x 500GB, Barracuda 7200.12 (RAID1), system disk
2 x 1TB Barracuda 7200.12, media disks
Windows 7 Pro 64 bit
Adobe CS4 Production Premium + latest updates
The problem I have has mostly to do with Premiere although I think the rest of Production Premium softwares should be running better on this computer as well.
For starters, I was highly disappointed when I couldn't view a single HD clip from the Premiere timeline (it was an .m2ts rip from a previously self-burned Bluray disc) at all. Rendering is very slow and even after that the video doesn't run normally, showing just a few individual frames per second. When I point the timeline at a certain spot, it takes many seconds until even that very frame is shown in the monitor window.
And this is not all - I decided to try with a basic DV AVI clip, previously captured with my PPro 1.5 on my earlier computer (3.2ghz Pentium from 2005). It's a native file so it doesn't even need rendering and still the same problem occurs. With normal playback only about 6-10 frames are shown per second. It's absolutely ridiculous - my 2004 laptop runs more smoothly with PPro 1.5.
While I'm running the Premiere, the level of used RAM comes only up to around 24 percents. The processor, then again, comes close to a hundred when play is pressed on the timeline.
I haven't had such immense problems with other Production Premium softwares (though as I said, I think they should be running faster as well). Otherwise the computer is running smoothly.
Some guy pointed out that the graphics card I'm using isn't on the Adobe website's list of supported ones with Premiere, but afaik it shouldn't even be a graphics card problem with this high-end machinery.
So - I sure could use some help and ideas about how to get the Premiere working. My intention was to start HD editing with this computer after all! Thanks beforehand!
