Major Problem!  PLEASE HELP!
ExFilms
I just digitized 6 hours of footage for a wedding I need to edit this week. I started to preview one of the clips in FCP and it was riddled with glitches in the audio and each successive glitch put the audio further and further out of sync with the video. I popped the tape back in and recaptured the clip with 'capture now'. As I watched the video on my NTSC monitor as it captured it looked and sounded fine. Then I checked the newly captured clip in my timeline...same problem. I freaked out and quickly checked several of the other captured clips and they all had the same problem. I ran a head cleaner through the camera I capture with and tried again, same thing. I then checked the footage from a wedding I did last month that was still on my hard drive and it was fine. I knew that the project I captured last month was good but I checked it just to rule out possibilities that my software or computer was doing something to it.
I have been doing this the same way for over a dozen weddings, same equipment, same settings. So maybe something is worn out? My camera perhaps? Here is what I have:
Sony VX2000 is being used as my source deck.
RCA's from the VX2000 feed video into my NTSC monitor.
Firewire from the VX2000 feeds into my Dual G4 Mac.
Mac is running OS 10.3.7 and FCP4 HD, 2gb of ram, dual 1.25ghz processors.
All audio/video is being captured onto a designated media hard drive.
The media hard drive consists of 2 raid arrayed 7200rpm 250gb Western Digitals.
My best theory (and my fear) is that the VX2000 is dead or dying. What adds to that theory is that towards the end of the capture of this wedding I was getting errors (actually only on the very last 2 clips I tried to digitize) I had never seen before saying that FCP wasn't getting good info and would abort the capture (not timecode break or dropped frame, something else). I thought this might of been a glitch on the tape itself since it was only those two clips out of 6 tapes. I remember watching the part of the tape that would cause the error and it looked fine when viewed through the camera.
And thats something that confuses me too. When I play the camera and watch it in the monitor (not the computer) it looks fine still. Could it be my firewire cable? I don't have another one to test.
Has this audio problem happened to any of you? I am so screwed if I can't get this fixed right away. If anyone knows of any other forums I can post this on I would appreciate it.
Thanks in advance.
Ex
Re: Major Problem!  PLEASE HELP!
[quote author=ExFilms link=board=FCP;num=1103788145;start=0#0 date=12/22/04 at 23:49:05]
My best theory (and my fear) is that the VX2000 is dead or dying. [/quote]
Have you tried to capture completely different footage using your VX?
Good suggestion.  I just gave it a try by capturing some footage from a completely seperate project, one that wasn't even shot on my camera.  Same thing happened.
I viewed the clip in FCP and it starts out ok, then glitches where the frame freezes momentarily and when it unfreezes the audio is out of sync.  Again as I captured I could see the direct feed via RCA's into my NTSC monitor from the camera and the footage looked and sounded flawless.  There were no errors on the capture (by errors I mean the error windows that pop up when FCP aborts a capture).  I did notice that the glitches showed in the FCP capture window on the computer screen during the capture.  So the footage that looked perfect on the NTSC monitor was apparently not being captured the way I saw it.
The first hing I would do is try another FireWire port on the Mac and then a different cable if that doesn't work.
If that's not it, then it sounds like it may in fact be the camera. Perhaps the FW port is damaged on it.
Good luck!
p.s. Six hours of wedding footage? Yikes.
May I ask, though, what you typically charge your clients for this service? I've thought about offering to do weddings for some extra cash, but not sure what folks normally expect to pay.
I'll try the port first then I'll get some friends to come over with their firewire cable and camera today to test that out.
_____________
btw...I charged $1500 for a one camera wedding and $2000 for a two camera (started at $800-$1200 then increased as I got better). I quit because it started out as a plan to finance my short film projects but it ended up making me want to go into convulsions every time I opened FCP. I have 3 weddings left to edit and I'm completely done...its agonizing. And women getting married are fully crazy. If you are looking at doing this for some extra money get a digital SLR still camera and do the photography side...you'll get twice as many clients, be able to charge twice as much, and there is no editing. I wish thats what I would have done.
Do you have enough disk space for system and footage?
(1-2GB for system)
Try posting on 2-pop.com or checking there for sync issues.
[quote author=Scottdvx100 link=board=FCP;num=1103788145;start=0#5 date=12/23/04 at 13:12:24]Do you have enough disk space for system and footage?
(1-2GB for system)[/quote]
Yes, plenty of hard drive space (1.25tb total) across 5 drives. One is a designated system drive with all the software on it, and I have a 500gb raid dedicated to video.
Thanks for the referal to 2-pop...I'll definitely check it out!
Turned out to be the camera. I tested everything and that was it. Hopefully this will be a good excuse to get a DVX. :)
