Magic Bullet Looks and FCP not working
miloca
Hi everyone,
I am having troubles with MBL in FCP, it used to work properly, launching the look builder fine and applying all the effects without any issues.
One day Looks from MB was gone in FCP's effect tab. I had all the misfire, but Looks was gone. Uninstalled it, then installed it again and now is there again, but doesn't launch. I get a window saying that my graphic card doesn't support MBL.
The weird thing is that it used to work and now it doesn't for some reason I haven't been able to figure it out.
Does anybody have a clue of this issue? Please help!!!
Thanks in advance,
C
PS: My computer: macbook 2.2 ghz
FCP: 5.1.4
MB has a project file it should of downloaded as well. I have mine in the documents so I can open it whenever needed.
As for your card, if I can remember correctly just disable the first option after you apply.
Hi Abu,
Thanks for replying... I don't think I understood what to do about disabling the first option after applying.
What I noticed is that the effect box after applying Looks to a clip, instead of "options" I get "register". I typed the serial, click ok, and nothing happens.
Cheers,
C
Hi Cieloent,
Thanks for replying... Sorry for the ignorance, but where do I change the render bit in FCP? I am using FCP 5.1.4 and did not find anywhere to change that.
Thanks again
C
Hi Cieloent,
Thanks again
C
Your timeline settings. Go to your file manager ( where you have all of your clips ) and simply right click on settings, it's in there
peace
