m2 question
scotman
if i buy an m2 SD bundle, is there anything else i need to buy that will make it work. Besided lenes., to attach my lens
and i am actually getting this lens, FYI
Nikon 50 mm 1:1.8
later
by purchasing the indie bundle you are ordering everything you need, except of course the lenses. Just make sure to specify you want the nikon mount and you'll be set.
I agree. One thing that I purchased and am so glade I did is the follow focus. At first you would think you don't need it because you don't, but after using it you won't want to do without it.
It actually does what the name states. It allows you to focus your adapted lens with ease of hand. It is basically a mechanical gear with a toggle nob which allow for a very smooth focus transition.
scotman said:
cnt you just do it with your own hand??
Like I said earlier. You don't need it, but after you use it you won't wanna work without it.
If you look at my avatar photo you will see the follow focus nob. Its the white and black nob with the sky blue center beneath the 35mm lens.
does the m2 only work with their own pull focus?? are there controllers that i can use for focus that hook up into a port on the dvx? if i can use another follow focus, what are they?? thanks so much. i did respond to the Instant HD forum
I'm not sure but I would think you could use another as long as it gives you the freedom to adjust and fine tune it to the rig. Before doing that I would contact redrock support and ask, or just ask the manufacturer of the focus your considering. Redrock was very helpful to me.
Thanks for the Instant HD respond.
YEa you can.... but its like, using a manual screw driver, or a power screw gun... sure you can do it by hand....... but why?
