Low res titles after render?
Craig Ryan
Now that my flicker issue is gone, I have another....After I render the titles appear low res...is there a setting im missing?
How are you creating the titles?
If this is happening in the reference monitor check your output setting and make sure it's set to the "Highest Quality" as shown below:
Last night I exported my short to MPG2-DVD from Premiere 1.5.1. I then took it into the Sony DVD authoring package, whipped up a quick menu and then burned it to a DVD-RW.
I fired it up on my progressive scan DVD player that is feeding my 30" HDTV set via component video. Everything looked GREAT! Except for the credit crawl at the end. The text looks terrible. On the PC in WM9, it's smooth as silk and looks great. Part of the credits involve panels that fade in and fade out and these are followed by the crawl. The text in those panels looks perfect. Only the crawl has issues.
Can anyone shed any light here?
I've experienced the same problem with my DVD that was encoded with VBR, but it was so slight that I never went back to fix it.. I was going to suggest trying CBR, but it doesn't look like that would work either if you are experiencing it.
Fixed it. I changed the font to Ariel Bold and put a slight yellow tinge to the color of the type and it looks stellar...
