Alpha Flying Monkey
I've done a couple of mixing/recording jobs with the Panasonic HMC150 & HVX200- on both occasions the headphone return is rather quiet... I'm using a 2 XLR & 1 stereo 1/8"snake from Wendt X3 Mixer to the camera. When I monitor the return volume the sound is almost half as quiet as the mix volume.
Should I add a headphone amplifier into the mix in order to get a stronger return signal? I've checked the feed to the cameras & that's been fine- it's just quite a bit difficult to hear the return. I've also made sure that the audio out is on full, so that hasn't helped.
