Looking for trusted data recovery software?
yasika11
Regards to all, I had some data copied to my pc a few days back and later on found that the hard drive was making some kind of a noise. This was not a problem at first…but now it is!!!!! The hard drive is now corrupted and I need the data back. I know there is software for this purpose but I need a tried and tested one…that one which has been used by you people and was good at its work.
Thanks in advance!!!!
Re: Looking for trusted data recovery software?
Well, there are many as you already know…..but if your hard drive is corrupted I doubt how many will make the task possible in this case. I personally use a software that is good even in data recovery and is also efficient to recover files from corrupt hard drives.I have been using this and had no problems of any sort till date….so I would advice you to go for this one without any doubts.
I've used the same one as well..works really well with a high level of recovery.
