Is there a portable recorder with 2x1/8" inputs for 2 lavalier mics, with separate volume knob for each mic and a 1/8" headphone output?
It can be a consumer grade recorder, intended to record conversations between 2 people under unique circumstance, for consumer use, so, please, don't suggest boom, dynamic mics and other such options.
Thanks.
Edit:
The recorder is needed for a very unique situation, not similar to conventional dialogue situations.
Therefore, the recorder MUST answer the following requirements:
2 x 1/8" inputs with phantom power suitable for lavalier mics.
Separate ROTATING volume control knobs – press switch volume control isn't suitable.
1/8" headphones output.
Ideally, the recorder will also have good input limiters.
Thanks.
Edit:
