look im done
FREE OF CHARGE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
This adapter is very simple to build. All you need is to follow these links!!!!
Here, I'm going to explain the process that I used.
The order of the rings:
THE LENS (I used a 50mm konica lens)
http://cgi.ebay.com/KONICA-HEXANON-...goryZ707QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
THE LENS ADAPTER ( I used a camera mount that was off the original camera)
http://cgi.ebay.com/KONICA-AUTOREFL...ryZ15236QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
THE STEP-UP RING ( I jb welded the LENS ADAPTER off of the camera to this piece for about 15 hours) MAKE SURE ITS EVEN!!!!!
http://cgi.ebay.com/New-55mm-58mm-M...egory040QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
THE SPACER (this is what you put your GG in, and for a perfect fit you'll need either tape or cardboard (to cut the hole & glue it), etc....
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=7028456&rd=1&sspagename=STRK:MEWA:IT&rd=1
THE GG (Now this part is the hardest part. I used a 55mm uv filter and 1000 grit to grind it)
(YOU CAN PICK THIS UP AT YOUR LOCAL HARDWARE STORE) *** This part requires alot of time, sometimes 3 days of grinding. Or you can just use a screen.)
THE 10X MACRO
THE OTHER 10X MACRO (you'll need two of these!!!)
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=759242404&rd=1&sspagename=STRK:MEWA:IT&rd=1
THEN THE STEP-DOWN RING. (this you screw into the end of the camera)
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=753095695&rd=1&sspagename=STRK:MEWA:IT&rd=1
Set the lens to infinity, then look through the GG (in the day time) you should see everything in focus. If so, that part is set (don't touch it).
Screw it onto the camera, set the focus to manual and zoom in about ZZ 72. Now, set the focus to MF07. Lastly, set your Fstop to about 2.8. That should work, if not check your settings again.
HERES WHERE I GOT THE IDEA FROM JUST MODIFIED A LITTLE!!!
http://www.enormousapparatus.com/35adapter.htm
CHECK OUT THE NEW ifocus 35mm adapter HERE----------------------------http://www.dvxuser.com/V6/showthread.php?t=44952
PLEASE GUYS NO MORE PMS, I CAN'T CHECK MY MAIL. THANK YOU
im not trying to make money I will sell my old one for $150 canadain thats what it cost me to make the older one but still the same gg.
TAHNKS
To: MIKEY
On picture #3 (1st page) I only see one!! Not unless you took my advice and changed it. Just trying to help!
its sunk in if you look really close... I tride with one but it sucks poop I would like to find a really strong x20 is that possible??
JB weld isn't actually welding - it's a type of glue that's mixed togther right before you use it and becomes as strong as metal when it dries. Available at any hardware store or auto parts store.
:thumbsup:
You can get it at walmart! Its about $5.00. Just make sure you let it dry for about 12 hours or so. Use a couple of books to hold it down over night.
To: mikey
It sunk in, what do you mean?
Don't want to put a dampner on things but if you look at the clip Full Screen,
There is Chromatic Abberation on the verticals.
Out of place question, forgive me, but what exactly is "Chromatic Abberation"?
"lenses also suffer from another type of abberation called chromatic abberation. This occurs because the index of refraction of the glass in a lens is different for different wave-lengths."
Cause the definition I found confuses me.
-rook
