Justin Numbers
[MOVIEHD][/MOVIEHD]
Shot 100gb of video using HVX200 & FS100...organized P2, went to HDD, enable bypass, drive shows up on MacPro can see a grip of folders starting at 0, going to what appears to be date and time folders with .mxf files..last clip file is there too.
Opened FCP, went to log & transfer like usual, and got a bit scared when it didnt recognize the FS100...no clips showed up in Log & Transfer window..i tried to set the path to the fs100 drive and got an error, not recognizing file structure on FS100.
called Focus Enhancements, they said to try to play the video through the camera, connected FS100 to HVX and it worked, I can see the footage (whew) so, i know its there just need to get it off...Focus Enhancements said if the footage played, the only way to get if off is to transfer from FS100 to P2 cards (i am assuming through the camera, not sure how this works)
How can I get the .mxf files off the FS100, need them as quicktime files, has anyone encountered this anomoly?
I need the wisdom and scolding of Shane Ross to make it through this situation...
