Livetype to FCP
How do you send your project from Livetype to FCP and render the livetype stuff in FCP instead of LT? There is supposed to be a little icon that you are supposed to click in LT that sends your stuff right to FCP providing you have FCP open. I cannot locate the little icon.
Check the manual for a more detailed explaination. But here is the quick and easy explainer-
(Make sure FCP and LT are both open.)
When you're done in LT save your project. Then in the top of the imteline window there is a graphic of a LT file (It is in the center). Use your mouse to click and hold on it. Still holding the mouse button down, use Command-Tab to change to FCP. Once in FCP you can place the file you are holding either in the time line or in a bin. You're set.
BTW- If you ever want to make changes to that file- right click on it and choose "Open in Editor" - make your changes, save, and switch back to FCP it will update in FCP.
check out this site for TONS of great how to's- (I believe around 140 to be exact.)
http://www.kenstone.net/fcp_homepage/fcp_homepage_index.html
