pmark23
Oh yeah, baby!
I ordered a carton of Osram film fluorescents from Germany -- only $10 each, including shipping! These will be used to build a unit of 20 lamps to simulate diffuse sunlight through a large window.
Ballasts are dual electronic Chinese. About $3 each. The only other ones available here are German for $70 :shocked: . Since I need 20, I'll be going for whatever's cheapest and works. The Chinese ones may need a bit of modification to stabilize the HF. They're quiet and don't get hot though.
The ballasts are rewired to overdrive the lamps by 2X, resulting in 1.5 times the output. The lamps are regularly 36 watts (2850 lumens) -- 200 tungsten-equivalent watts. Overdriven each will pump-out 300 tungsten-equivalent watts per tube. 20 lamps will produce a tungsten-equivalent 6K fixture, and only consume 1kW.
Still experimenting with ballasts, but things look good so far...
