Lighting setup for this scene from: The Conjuring
starcentral
Anyone want to take a stab at the lighting setup for this?
My best guess would be either a very large single point source (or more likely three single point light sources: bed, door, dresser) due to the high contrast. The digital banding hotspot artifact over the dresser makes me inclined to think it is three lights. The light over the dresser appears to be spotted so unlikely to be the same as on the bed and the spot is round and not cut off by the closet edge (which has its own hotspot) so presumably not the same source. Some flagging is probably used where the lights overlap. Is that a c-stand in shot on the right? Is this a production still or frame grab? By the area covered I'd guess high wattage lights gelled and/or dimmed/scrimmed to change the colour temperature and light intensity. The contrast with the colour temp of the ensuite enhances the lighting effect. That's my take on it anyway.
it is screen shot from film
I feel like there are a few soft light sources at work here likely gridded, the shadows on the lamps on the wall match the shadow of the chest in front of the bed, or seem to. Maybe its one massive soft source at head of bed. but then you can see what look like hard light sources reflected in the metal bits around the bed there.
no idea.
It wouldn't surprise my at all if there were fifty lights in there based on behind the scenes images from any film. But it does look pretty sparse to my eye. You can only really work off the highlights because the digital image is struggling with the low dynamic range. I can't tell if the walls are dirty or in shadow. For example the wall on the left by the door has dark smudge just above the line of the dresser which I assume is dirt/mildew or something of that nature but could be a shadow off the dresser from a weak low source. Or the edge of a flag.
The rug might be a separate overhead soft source because if the bed light is where I think it is half of it would be in shadow. This looks like the most straightforward simple lighting setup but it could in fact be dozens of lights painstakingly set up to look like the most straightforward simple lighting setup. I think the ceiling lightshades might have their own light as well. I'm still pretty sure the lights are hard lights though and any softness might be from heavy scrimming perhaps? Or from layers of gel? To get that amount of throw while having discernable hot spots I couldn't see these being low powered lights from a distance. But I'm being a keyboard warrior here, I'm no DP.
Even though I originally thought there were multiple lights (highlighting the wall above the dresser, the door, etc), I think all of that could be coming from the same source off screen right.
In this picture, all the shadows indicated by blue arrows are telling me that the light is coming from that same source. The sconces on the wall above the dresser are casting shadows in the same direction, again indicating the single source off frame right, the shadows wouldn't look like this if the wall highlight was lit from above. And that "smudge" you talked about, I believe is a soft shadow coming off an item on the dresser (which you pointed out), that would be the same source.
The green arrow is to show the falloff on the door, which looks like the right edge of a spot.
Even the chandelier lights look like they are only lit by a soft source off frame right. All signs (at least to me) point to that being a single source of light for that room. Which makes sense, especially with night interiors which tend to replicate moon light ambience (soft blue single source) accented with yellow practicals.
Looks like one big soft source off to the right to me. Plus something a touch more tungsten-ey what I assume is a hallway outside the door (frame left)?
I'm going to have to watch the film again and catch other angles of that room. Could be there was a window over the bed that was used. Quite sure I read somewhere these were real locations with tight spaced, so Director James Wan used 14mm lens tons for interior shooting.
production design is doing alot here, everything in there is likely brown, grey, desaturated....no framing out the bright yellow box o' cheerios atop the fridge
