Lighting for interview
Interview Lighting
Interview Lighting
If you light on stage then you need at least three lights...
Key, Fill and Backlight.
If want to get fancy than add one more light for background.
If the interview takes place at the natural location, position your subject sideways close to the window and utilize windowlight as a key light... it is better when this window faces north because this key light will be a Soft Light.
You will bring a large white card from the oposite side and bounce the window light back to the face... this will be your Fill Light. In this situation if you have at least one light than bouce it from camera side (straight over the camera)... this will give you an Eye Light.
I bought this video from Vortex Media:
http://www.vortexmedia.com/LightingDVD/LIGHTING.html
I bought most of this lighting gear it recommended, and it has improved the look of my interviews immensely. The most irreplaceable piece of equipment for me is the black egg crate for the soft box. It keeps light off your background and allows you to create a much more professional look.
to be honest, for an indoor interview you can get away with paper diffusers and practical hardware lamps... just make sure all the bulbs are the same color temperature
NASSAR:
Here is exactly what I ordered from B&H (qty x cost):
Lowel LOC16TL
Cable with Line Switch for Omni, DP, Tota-Light, Caselite - 16' REG (1 x $27.50)
Matthews MAHWH2.5
Hollywood Grip Head - 2-1/2" REG (1 x $29.95)
General Brand GBGCA
GCA Lamp - 250 Watts/120 Volts REG (1 x $18.95)
Lowel LOPLL
Pro-Light Tungsten Focusing Flood Light with Bulb (120-230V AC/12-30V DC) REG (2 x $119.95)
General Brand GBFDN
FDN Lamp, Frosted - 500 Watts/120 Volts REG (2 x $13.95)
Rosco ROCSK
Cinegel Sampler Kit REG (1 x $32.00)
Photoflex PHSDS
Silverdome NXT Softbox - Small - 16x22x13" (41x56x33cm) REG (1 x $109.95)
Flexfill FLAH
Adjustable Holder for Collapsible Reflectors REG (1 x $49.95)
Lowel LOBD4PL
4 Leaf Barndoor Set for Pro and i-Light REG (1 x $34.95)
Avenger AVA625B
A625B - Midi Kit Stand - Black, 7' 10" REG (2 x $59.95)
Avenger AVA630B
A630B - Midi-Max Kit Stand - Black, 10' 8" REG (2 x $77.95)
Photoflex PHSM
Heavy Duty Swivel Mount REG (1 x $22.50)
Photoflex PHGS
Nylon Fabric Grid - Small REG (1 x $88.95)
Bogen / Manfrotto BO3398B
3398B - Convertible Boom Stand 420 (Black) REG (1 x $122.95)
Impact IMD600
D-600 Dimmer Control - 600W Maximum REG (2 x $24.95
Photoflex PHSRLTQ
Speed Ring for Lowel Tota, Omni Light REG (1 x $79.95)
I put my vote in for (at the least) a Home Depot type CFL spiral lamp type solution or pro level fluorescent fixtures. Why heat the talent and room up?
