audionandfilm
I was not sure where to post this. I might have to post this in more than one place on the forum to get information for the project. So, I am doing a project involving caves. I am not going to bring expensive lighting gear. It will get destroyed easily. I am thinking about getting powerful flashlights / battery powered stuff. I can afford to lose those but not $1000's in lighting gear. Maybe some combination of flash lights, hand held floodlights, or whatever available that is affordable to lose. I am looking for gear I can pack into bag or at least carry hand.
Will Gels work on a flash light or battery powered light?
I am going to be doing things like crawling in passages, crawling through deep mud, walking through streams, jumping off cliffs on rope, and climbing. Running a generators and cables is out of the question. Caves have 100% humidity. The temperature of the ones I will be in are around 50 degrees. They can be loaded with mud and very fine dirt that gets into everything.
I am leaning towards using DSLR because they are small and easy to carry around. I am open to other suggestions to cover the camera.
Any suggestions on DSLR cameras or cameras that can be lighted with flashlights?
For sound, I am trying to keep it simple and light. It will be a shot gun and a H4N probably. It is a lot easier to carry that than a audio bag with a mixer, wireless, and recorder. In addition, all that stuff would get destroyed in cave a easily.
I am thinking small pelican cases and waterproof bags to put gear in like you use to for kayaking when traveling between places in a cave.
***** Anyone shot with battery powered flashlights, lanterns, or related type lights or have suggestions? If so, what did you use or can suggest? ****
Any other suggestions on gear & filming in a cave in general would be appreciated.
