Lighting a train carriage
gspoljaric
Hi, all. Any advice for lighting the inside of a train carriage? The train's supposed to be travelling at night, so its fluorescent lights are supposed to be on. I have attached a picture of the carriage I'm using. The carriage is in a yard, so there's no power to these lights. I imagine I will have to replace the lights somehow, but how do I do this and with what lights specifically? How easy is this to do? Judging by the number of lights on the ceiling, I would need quite a few.
Thank you in advance, community.
The good news is that judging by the look of the covers, they're probably standard fluorescent tubes, although may require a specific voltage used by auto electrical systems (or maybe trains use a special voltage all of their own?). In fact, the tubes may still work - presuming they haven't been removed.
Power is the harder issue, as ideally you'd want to reuse the existing wiring (if it works) and just somehow hook up a transformer to supply the power, mimicking the normal train power supply - you need to talk to an auto electrician with train expertise (he/she will also be able to advise re the tubes). Could be an easy job, could be hard, could take him/her a few hours of tests and fiddling to find out.
At worst, yes, you'd have to rip out all the lights and replace them with standard fluorescent tubes, but at least they're generic-enough-looking that finding replacements should be easy.
