Lighting a car scene cheaply...
I have a 26 amp hour jumpstart battery pack that will run a 60W draw LED spotlight for over three hours. A typical car battery is between 40 and 120 amp hours. It should be written on it. A 60w bulb for 110V will draw only slightly more than half an amp with a bit more lost through inverter inefficiency. For comparison your car headlights are ~110W from 12V so draw slightly more than 9 amps. Which means unless your battery or 12V socket is faulty you should be able to run that light for many hours with the engine off and indefinitely with the engine on. In fact you could easily run 3. I have an inverter in my workvan and I can run a cable tv decoder box, tv, drill battery charger and several pieces of test gear for at least 3 hours with the engine off without any fear. There's a lot of juice in a car battery. It can throw you across the room if you grab the terminals.
I agree, a CFL bulb (or a couple) plugged on a 75w inverter is plenty enough for that kind of work. A 100w equivalent CFL bulb will draw like 0.20W/bulb as it consume like 23w.
You can put more than one bulb to add to the ambiance (front and back seats).
Another thing I was watching for car scenes at night were these:
Not exactly like that:
...but you'll get the point!
Similar to what they've done in Collateral, sticking it on the top on the interior of the taxi:
More info in this thread.
But my battery sucks! Although it did do decently I don't trust it. I hope to get a new battery soon. When I left the car in park it acted like it wanted to die after a few minutes. It started back up, but yea, I've been having issues.
-Nate
-Nate
These days I don't have too much in the way of 'battery problems', but last year I did leave the lights on on my car, and drained the battery. The 'alarm' decided to be constantly on even though I charged the battery up, until I found a way (on line) to reset the alarm.
But on the topic of car interior lighting... I'm looking at some of the 'par' LED lights that are coming out. Low wattage, high lumen output. They may be 'too' hot for direct light but with bounce could provide a pretty cheap solution as well... perhaps not as cheap as a 60W tungsten... but those are going out of stock in the usual places anyway...
-Nate
If you are having electrical issues while the engine is running or if the battery doesn't seem to be charging while you drive might be worth having the alternator looked at too. My brother is having similar issues at the moment.
I have successfully used 2 strings of Christmas tree lights lying on the actors laps. Looked like the light was coming from the dash
You can find LED stick lights that run on their own batteries too, its like a metal tube with LED's that takes 3AAA batteries... great for any temporary use, just add some diffusion if you like then stick it to a wall, or add velcro, or twist tie to whatever... etc..
http://www.homedepot.com/p/Sylvania...rizontal-Light-Stick-72463/203109732?N=25egxd
