j Veteran Aug 2, 2006 #2 sekonic is the standard. Incident - 398 (~$180) http://www.bhphotovideo.com/bnh/con...889&is=REG&addedTroughType=categoryNavigation Spot - 558 (~$500) (it's also an incident meter) http://www.bhphotovideo.com/bnh/con...423&is=REG&addedTroughType=categoryNavigation Although I do love my Pentax spot meter V. It's analog meter cannot be matched in the digital world. Nothing like sweeping that thing across a green screen or white cyc... http://cgi.ebay.com/Pentax-Spotmete...3QQihZ014QQcategoryZ88669QQrdZ1QQcmdZViewItem If you get one used, make sure you get it recalibrated! QUALITY LIGHT METRIC CO. 7095 Hollywood Blvd. #550, Hollywood, CA 90028 Phone: 323-467-2265
j Veteran Aug 3, 2006 #4 Gossen makes one for ~$160, but I've never tried it - I'm a big fan of analog readings. The Sekonic 508 is digital and has both incident and spot.
S steadicamsteel Guest Aug 3, 2006 #5 I use the Sekonic 608 but I believe they no longer manufacture them. Bloody good meter though.
S Sidney Tawl Member Aug 3, 2006 #6 The Spectra 4A is a great incident meter. It will be found on the belts of many gaffers and DP's. I have seen them for sale to students at a very discounted price. a spot meter is a good meter to have in your bag. Most spot meters stay in the bag unless a situation arises that calls for them. I have a Sekonic Dual spot F with the Spectra 4 A and I carry it. Even the digital meters need to be calibrated every so often, and if you drop it then you should send it in to be recalibrated. First thing a DP and his Gaffer will do is put their meters under a source and see if they match. EVen when different brands
khmuse Tech Guru Aug 3, 2006 #7 I gotta agree with 'j' a Pentax Spot Meter V is a great choice for a lot of situations. Add a gray card and you have a really good and repeatable tool.
